V92 Softmodem
Discussion in '3CX Phone System - General' started by retellect, May 8, 2012.
  1. retellect
    May 8, 2012
    Based on the topic you have probably figured what my question is going to be :D My first install of 3cx and it looks great so far, successfully added 2 voip gateways and they work fine, allowing me to make and receive calls using softphones and a Cisco IP phone I acquired.
    Can I use a normal V92 controller-less softmodem as a bridge between voip and pstn (for free local calls)? I've seen some people using modified drivers that allow these modems to pass-through, particularly on Asterisk . The answer is no right? I suppose loads of people have surplus voice/data modems, who knows if someone wrote a CPU efficient driver to support this!? haha
    11,283
    360
    You are correct....you require a Gateway, for a connection to PSTN lines.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Its not just a driver issue. 3CX only communicates via SIP. For an internal card to work, be it a modem card or even a Digium FXO/FXS card) you first need a Windows driver to communicate with the card and then you need some additional software that communicates with the card and creates a SIP trunk that 3CX can talk to.
