VAD and Text File Management Component
Discussion in 'CRM / Helpdesk / App Integration' started by David B, Jun 4, 2012.
  1. David B
    Jun 4, 2012
    Dear All,
    I need to compare a text file with a VAD variable. I don't know if it's possible to transfert text file content to a variable?
    I wish to compare "session.ani" to a list of call number, in order to filter calls.
    Thanks,
    David
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Yes, it's possible using the File Management component. You can read the entire file and store the content into a variable. Then you can use expressions or a simple javascript function to validate if the ANI is into the list.
