VAD: cannot add sting-variabele to Database.scalarresult
Discussion in 'CRM / Helpdesk / App Integration' started by rhennink, Dec 23, 2011.
  1. rhennink
    Dec 22, 2011
    I have a little issue with the VAD-designer, and could not post this message in the VAD-Forum itself.
    the problem is simple I believe:
    - I get a data-value from a SQL-database
    - I send a e-mail message with in the body the variabele: dbGetSupportEngineer.ScalarResult
    - everything is ok
    but when I add a string to this variabel, it won't work
    - Example is: 'test'+dbGetSupportEngineer.ScalarResult
    When I add another variabele, it works fine
    - Example is: 'test'+session.ani
    What am I doing wrong??
    Richard
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Use the VAD function "CONCATENATE" in order to concatenate a string to the database result. That should work.
    This is because the properties of objects have a different name in the javascript that is generated, except by the session object. So, that works with session.ani for example, but it doesn't work with any other object. Try using the provided functions and you will get it to work.
