VAD database Access
Discussion in 'CRM / Helpdesk / App Integration' started by Yama, Jul 10, 2014.
  1. Yama
    May 23, 2014
    Hallo was mache ich hier verkehrt? Schau bitte Bild.
    Der Anruf beendet nach 1sekunde und im Debug kann man sehen, dass ist DatabaseQuery,Scalar,NonQuery "undefined" steht.
    Ich gehe davon aus, das die Verbindung zum SQL-Server fehlschlagt.
    Hello, what i make here wrong? Please the the picture.
    The Call canceled in the first second. In Debug i see that the DatabaseQuery,Scalar,NonQuery is "undefined".
    I'm assuming that fails to connect to the SQL server.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there,
    Do you have project variables with those names? For example a project variable named 12128HSQdUYw?
    If you need to use constant string literals, you need to put the value with single quotes, and not with project$ before. For example:
    '12128HSQdUYw'
    The same applies to the fields Server, Database, UserName and Password.
    Kind regards.
