VAD design won't deploy to V14 Cloud install
Discussion in 'CRM / Helpdesk / App Integration' started by ericosborn09, Mar 6, 2016.
  1. ericosborn09
    Dec 3, 2015
    30
    Just upgraded our 3CX server to cloud version to allow for multiple tenants. After doing so, VAD is no longer finding any instances and we're unable to deploy. I've already re-installed thinking it would find it during install and looked through registry but didn't see anything referring to type of server. All documents seemed to be based on old version of VAD, as I'm unable to select what version and Web type etc.
    As a workaround, we are able to Create a deployment package, run it on the same server and it finds the instances. Weird? This is okay but makes R&D very difficult.
    Any ideas? Thanks everyone!
    Eric
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,361
    109
    Hi Eric,
    That's a known issue in the latest version of the VAD. It will be fixed in the next release, meanwhile you can use the deployment package.
    Kind regards.
  3. miko
    Oct 14, 2011
    7
    Deployment package doesn't find tenants either - only provides option to deploy directly. Eric, were you doing anything particular to get the tenants to list?
  4. edossantos
    Jun 27, 2007
    1,361
    109
    Are you in v14? Can you share a screenshot?
  5. ericosborn09
    Dec 3, 2015
    30
    Miko, deployment package found them without problem. edossantos, any ETA on the release of the fix that you know of?
  6. edossantos
    Jun 27, 2007
    1,361
    109
    I don't have an ETA, but will be soon...
  7. miko
    Oct 14, 2011
    7
    Please see attached...
  8. edossantos
    Jun 27, 2007
    1,361
    109
    Hi Miko,
    Checking the stack trace, I see that the VAD is not detecting that your server is a cloud server.
    This is checked from the registry, so please tell me the values you have here:
    HKLM\SOFTWARE\Wow6432Node\3CX\PhoneSystem\ConfigVersion
    HKLM\SOFTWARE\Wow6432Node\3CX\PhoneSystem\INSTALLATIONMODE
    Thanks.
  9. miko
    Oct 14, 2011
    7
    In the order you have them:
    14.0.44241.523
    MULTI
    Regards
  10. edossantos
    Jun 27, 2007
    1,361
    109
    Hi there!
    For other users that might have the same problem, the issue was related to 3CX Phone System installed in a different folder than the default program files folder. It was a bug in the VAD always looking for a configuration file in the default folder. This is fixed now.
    Kind regards.
