VAD or Built in
Discussion in '3CX Phone System - General' started by CCSNET, Jan 24, 2014.
  1. CCSNET
    Nov 4, 2010
    10
    I have a potential requirement for VAD but i'm unsure if i can so it another way
    We have 5 departments each at the end of a DID and IVR, each of the handsets for the departments are in ring groups etc...
    a requirement has come in to have each department be able to switch there "lines" off and on at will, for example for a department meeting etc...
    i.e. ext 101, dials xxx and all incoming calls then get diverted to a VM "department is closed for meeting try again in x minutes" etc...
    I know i can force the entire system to switch to night but how would i do a department ?
    regards
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    There is no provision currently available that allows for subsets of grouped extensions to be managed in the manner you have described. While you mention "5 different departments, each at the end of a DID and IVR....", I am unsure if this is actually what you meant. If so, then there is only 1 DID per department and the easier way to accommodate the stated need is to simply divert the DID to a different routing, when necessary, be it a common mailbox for that DID/department with your desired greeting or other routing. This eliminates the need to maintain an ever-changing grouping of extension subsets. It will also eliminate the harm that might come in the event that some extensions are exposed to more than the 1 DID.
    On the other hand, the above does not address other avenues of ingress such as calls coming in from a different DID or main number and being transferred to the extensions. I assume internal calls would be handled just as the defined rules state.
  3. GManNAtl
    Sep 13, 2012
    58
    One possible work around, but I have not tested it :
    Instead of pointing the calls to the Ring Group pilot directly. Point them to a dummy extension where "In the office" it forwards to the ring group and "out of office" forwards to the mailbox. You can then call into the vm and change the presence status or use MyPhone on the dummy extension to change the status.
