VAD outbound call
Discussion in 'CRM / Helpdesk / App Integration' started by ice, May 12, 2010.
  1. ice
    ice New Member
    Jun 11, 2008
    108
    I need to implement the following function.
    The operator presses a button in the CRM, then application automatically calls to the customer and announce the recorded phrase.
    Is it possible in VAD?
    If yes, with what component?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    In order to launch an outbound call you need to use the HTTP API:
    http://www.3cx.com/blog/docs/3cx-http-api/
    You can configure your CRM to launch the outbound call using that API, and connect it to a VAD callflow (VAD callflows are registered as extensions). Then, you create the VAD callflow to reproduce the prompt you want. To do that, you only need to use a Prompt Playback component.
  3. ice
    ice New Member
    Jun 11, 2008
    108
    Thanks!
