VAD - Prompt Plays at incorrect time
Discussion in 'CRM / Helpdesk / App Integration' started by Tertius, Jan 12, 2017.
  1. Tertius
    Feb 24, 2016
    43
    We have created an IVR with VAD and all components are working as expected except for 1 External Code Execution component.
    We are required to make a SOAP connection to a CRM provider and do a validation based on DTMF provided by a caller. We have a prompt component which states: "Please wait while we validate" which is positioned before our code execution.
    Our problem is that the code execution component is started before the prompt, and only after the validation is completed does the prompt play.
    Has anyone experienced this before? Any and all help would be greatly appreciated.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,677
    131
    Hi, the problem pretty sure is that you're setting AllowBargeIn=True. That causes that the prompt is queued until a menu or user input component is reached. Change the property to False and the prompt should be played immediately.
    Regards.
  3. Tertius
    Feb 24, 2016
    43
    Hi Ernesto,
    Thanks for the timely response. Unfortunately your advice did not resolve our problem. We changed the BargeIn setting on numerous prompt components that were either directly before/after the External Code Execution or near by. We will however continue tetsting with this new information in mind and will revert back with updates.
    If you have any other helpful directions please let us know
    Thanks in advance
  4. edossantos
    Jun 27, 2007
    1,677
    131
    Hi there,
    Setting AllowBargeIn=False in the PromptPlayback component just before the ExternalCodeExecution component should do the trick. But If not, please enable Verbose logging as explained here, and send us the 3CXIvrServer.log file so we take a look.
    Regards.
  5. Tertius
    Feb 24, 2016
    43
    Ernesto please check your conversations as I have forwarded the log fle as per your request. We urgently require assistance with this matter.
    #5 Tertius, Jan 16, 2017
