VAD Samples
Discussion in 'CRM / Helpdesk / App Integration' started by ice, Aug 16, 2009.
  1. ice
    ice New Member
    Jun 11, 2008
    108
    After deployed Attended sample I recieved IVR session error (by voice)
    With second sample (dialer) the same situation
    How to resolve this?
    3CX v.7.1.7139
    .NET 2.0
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    What Operating System are you using? Are you calling to the extension where the callflow has been registered? Or are you calling a DR that calls the callflow when the you press an option?
    Can you post the file C:\Documents and Settings\All Users\Application Data\3CX\Data\Logs\3CXIvrServer.log to see a detailed description of the problem?
    Thanks.
  3. ice
    ice New Member
    Jun 11, 2008
    108
    Win2003Srv
    When calling direct to extension I received IVR session error.
    When calling to DR just silence.
    Code:
    2009/08/17 >>
    19:40:15.109|3092|.\3CXIvrService.cpp(892):IvrService, main(), Starting service, revision 7.1.6917.0
    19:40:15.109|3352|.\3CXIvrService.cpp(637):IvrService, MainServiceProc::Run(), Initializing php updater
    19:40:15.109|3352|.\3CXIvrService.cpp(646):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    19:40:15.109|3352|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    19:40:15.109|3352|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 7.0.6899.0
    19:40:15.125|3352|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    19:40:15.125|3352|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5484/ivr_start.aspx'
    19:40:15.156|3352|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    19:40:15.156|1492|.\SLAgent.cpp(237):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    19:40:27.312|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[802,801,853,851,852][805][MakeCall]
    19:40:27.312|1492|.\PbxMedia\IVREngine.cpp(899):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:999
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(939):IvrService, IVREngine::RegisterLines(), Registering IVR:802
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(939):IvrService, IVREngine::RegisterLines(), Registering IVR:801
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(939):IvrService, IVREngine::RegisterLines(), Registering IVR:853
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(939):IvrService, IVREngine::RegisterLines(), Registering IVR:851
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(939):IvrService, IVREngine::RegisterLines(), Registering IVR:852
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(960):IvrService, IVREngine::RegisterLines(), Registering Queue:805
    19:40:28.421|1492|.\PbxMedia\IVREngine.cpp(983):IvrService, IVREngine::RegisterLines(), Registering MakeCall helper
    19:40:28.437|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    19:43:39.828|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[802,801,853,851,852][805][MakeCall]
    19:43:39.828|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    2009/08/18 >>
    18:50:20.531|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[802,801,853,851,852][805][MakeCall]
    18:50:20.531|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    18:51:20.843|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[802,801,853,851,852][805][MakeCall]
    18:51:20.843|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    18:52:16.265|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[802,801,853,851,852][805][MakeCall]
    18:52:16.265|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    20:27:31.453|2136|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/(S(5crzkuf0enhjyg55isameeqv))/SimpleAttender_12/Callflows_Attender.vxml?dr=851&to=851&from=101MethodGETError-404
    20:27:31.453|2136|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc50
    20:27:31.453|2136|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriSimpleAttender_12/Callflows_Attender.vxml?dr=851&to=851&from=101
    20:27:31.453|2136|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    20:27:42.031|2780|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/(S(1k3tqa55ex4xnn3hzrxny355))/SimpleDialer_4/Callflows_Dialer.vxml?dr=853&to=853&from=101MethodGETError-404
    20:27:42.031|2780|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc50
    20:27:42.031|2780|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriSimpleDialer_4/Callflows_Dialer.vxml?dr=853&to=853&from=101
    20:27:42.031|2780|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    20:28:12.234|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[801,853,851,852,802][805][MakeCall]
    20:28:12.234|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    20:28:17.750|1220|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(a3hosnijqzvbjaazubfwyarw))/dr.aspx?dr=801&to=801&from=101
    20:28:34.781|1220|.\api\VXItelImpl.cpp(148):IvrDll, VXItelImpl::Impl::IntrnTransfer(), Error! Error of 'From_101_To_801_Menu_801_#0/2' session transferring to sip:100@127.0.0.1:5060. Status: UNKNOWN. Session disconnected
    20:28:34.781|1220|(0):Error! Module '3CX.com.vxi'. Error ID 441. messageunexpected result code
    20:28:44.906|3236|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(20wvkx55jlmgmjvcs5rqfb55))/dr.aspx?dr=802&to=802&from=101
    20:28:51.140|3236|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(20wvkx55jlmgmjvcs5rqfb55))/dr.aspx?dr=851&Action_0=1&act=0&transfToIVR=1
    20:29:08.578|3236|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x012803E0 not found
    20:29:18.703|1492|.\PbxMedia\IVREngine.cpp(883):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[801,853,851,852,802][805][MakeCall]
    20:29:18.703|1492|.\PbxMedia\IVREngine.cpp(1036):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    20:29:27.984|1612|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/(S(5rqtuuf3ti3bjp45xubjwxql))/SimpleDialer_4/Callflows_Dialer.vxml?dr=853&to=853&from=101MethodGETError-404
    20:29:27.984|1612|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc50
    20:29:27.984|1612|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriSimpleDialer_4/Callflows_Dialer.vxml?dr=853&to=853&from=101
    20:29:27.984|1612|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    20:29:36.312|3408|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(0dkgb145hbjnlurljfr1yo55))/dr.aspx?dr=802&to=802&from=101
    20:29:42.281|3408|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(0dkgb145hbjnlurljfr1yo55))/dr.aspx?dr=853&Action_0=1&act=0&transfToIVR=1
  4. VAD_Support
    Aug 6, 2009
    690
    The problem reported is a 404 (file not found) when trying to execute the main callflow (Callflows_Attender.vxml).
    Can you check if the file is is the web server? It should be in C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr\SimpleAttender_12\Callflows_Attender.vxml.
    Did you install server side components before deploying the sample project?
  5. ice
    ice New Member
    Jun 11, 2008
    108
    No, the folder was not created.
    Yes.
    Error disappeared after reinstalling sever components and re-deploying application.
    Thank you!
  6. VAD_Support
    Aug 6, 2009
    690
    Good to know. Thanks!
  7. Roshen
    Jan 16, 2009
    35
    Hi I have a simmilar issue.
    However I have the 3cx on a winXP machine
    the folder SimpleAttender_12 in C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr\ does not exist.
    I have reinstalled the serverside components and tried to redeploy.
    and other suggestions?
  8. VAD_Support
    Aug 6, 2009
    690
    What version of 3CX are you using?
    Did you change deployment settings? Windows XP in 3CX V7.1 requires a different configuration than other operating systems. That is explained in the users manual. Can you describe how are those setting configured?
  9. Roshen
    Jan 16, 2009
    35
    hi
    yes, in the options menu:
    C:\Documents and settings\user\...
    localhost
    5485
    http://localhost/ivr/VAD_Deploy.aspx
    " localhost/ivr/VAD_DownloadDebugInfoFile.aspx
    " localhost/ivr/VAD_GetDebugFileNames.aspx
    The 3CX version 7.1.7139.0 and VAD version 1.0.0.15
    the call flow appears in the DR container, but when i dial it "error in ivr... sorry" and just silence when directed there through another DR.
  10. VAD_Support
    Aug 6, 2009
    690
    There is a known problem when redirecting to a VAD callflow from another DR...
    A possible workaround until this is fixed is creating a dummy extension, and configure it to forward all calls to the VAD callflow. Then, configure your DR to go to that extension when the option is selected. Let me know if this works for you.
