VAD support issue
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 5, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    To VAD Support.
    I am banging my head over a problem, that should be simple.
    I'm sending you a VAD project. It has a .sql script for a sql express instance for it to work included.
    I am having a problem where after a call flow is completed it will always replay the last audio file before disconnecting. I am have combed the logged files and cannot figure this one out.
    All you have to do is enter ext 854 after deploying it and you'll be able to reproduce it right there.
    Can you please help? You can reproduce the problem immediately from the project I'm sending. I've reproduced it on multiple machines with this same project.
    And the web server log
    Code:
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/ivr_start.aspx IVRHandlerFROM=145&IVRHandlerMENU=854&IVRHandlerTO=854&ISID=From_145_To_854_Menu_854_%230%2F69 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 302 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/ivr_start.aspx IVRHandlerFROM=145&IVRHandlerMENU=854&IVRHandlerTO=854&ISID=From_145_To_854_Menu_854_%230%2F69 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 31
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/root.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp.vxml dr=854&to=854&from=145 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DebugInfo.aspx application.MenuResult_InvalidOption=InvalidOption&application.MenuResult_Timeout=Timeout&application.MenuResult_ValidOption=ValidOption&application.RecordResult_Completed=Completed&application.RecordResult_NothingRecorded=NothingRecorded&application.RecordResult_StopBySilence=StopBySilence&application.RecordResult_StopDigit=StopDigit&application.UserInputResult_InvalidDigits=InvalidDigits&application.UserInputResult_Timeout=Timeout&application.UserInputResult_ValidDigits=ValidDigits&application.WrapUp_CallerID=&application.WrapUp_NextComponentUri%24=&application.WrapUp_NextDisconnectHandlerUri%24=&application.WrapUp_NextErrorHandlerUri%24=&application.project%24_CurrentErrorDescription%24=&application.project%24_CurrentErrorName%24=&application.project%24_SqlDBName=WrapUpCodes&application.project%24_SqlPassword=wrapup&application.project%24_SqlServer=localhost&application.project%24_SqlUserName=WrapUpCodeUser&application.project%24_UseSqlLogging=true&application.project%24_WorkingDirectory%24=C%3A%5CProgramData%5C3CX%5CData%5CHttp%5CInterface%5Civr%5CWrapUpCodes_Debug_86&session.ani=145&session.callid=From_145_To_854_Menu_854_%230%2F69&session.dnis=854 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 11
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 2
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_assignCallerID.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_assignCallerID_DebugInfo.aspx WrapUp_CallerID=145 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 9
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_ReadConfigValues.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_ReadConfigValues_0_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 1
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_ReadConfigValues_groupConfig.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_ReadConfigValues_groupConfig_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_getSqlLogging_Prefix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_getSqlLogging_Prefix_DebugInfo.aspx application.Components_ReadConfigValue_In_ConfigKey=UseSqlLogging&application.Components_ReadConfigValue_In_DefaultValue=false&application.Components_ReadConfigValue_NextComponentUri%24=WrapUp_MF_getSqlLogging_Suffix.vxml&application.Components_ReadConfigValue_NextDisconnectHandlerUri%24=WrapUp_DisconnectHandler.vxml&application.Components_ReadConfigValue_NextErrorHandlerUri%24=WrapUp_ErrorHandler.vxml&application.Components_ReadConfigValue_Out_ConfigValue=&application.WrapUp_getSqlLogging_In_ConfigKey=&application.WrapUp_getSqlLogging_In_DefaultValue=&application.WrapUp_getSqlLogging_Out_ConfigValue= 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_assignDefaultValue.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_assignDefaultValue_DebugInfo.aspx Components_ReadConfigValue_Out_ConfigValue=false 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_queryConfigValue.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_queryConfigValue_DoIt.aspx dataSource=&database=WrapUpCodes&parameterCount=1&parameter_0=UseSqlLogging&password=wrapup&server=localhost&userName=WrapUpCodeUser 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_checkIfConfigValueEmpty.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 11
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_checkIfConfigValueEmpty_0_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 9
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_checkIfConfigValueEmpty_ConfigValueFound.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_checkIfConfigValueEmpty_ConfigValueFound_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 15
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_assignConfigValue.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Components_ReadConfigValue_MF_assignConfigValue_DebugInfo.aspx Components_ReadConfigValue_Out_ConfigValue=true 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_getSqlLogging_Suffix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 7
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_getSqlLogging_Suffix_DebugInfo.aspx application.WrapUp_getSqlLogging_In_ConfigKey=UseSqlLogging&application.WrapUp_getSqlLogging_In_DefaultValue=false&application.WrapUp_getSqlLogging_Out_ConfigValue=true 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 15
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_assignSqlLogging.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 20
    2011-10-05 15:46:19 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 63
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_assignSqlLogging_DebugInfo.aspx project%24_UseSqlLogging=true 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 64
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 9
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_LogIVREntry_Prefix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_LogIVREntry_Prefix_DebugInfo.aspx application.Logging_WriteLogEntry_LogMessage=Call%20entered%20wrap%20up%20call%20flow%3A%20145&application.Logging_WriteLogEntry_NextComponentUri%24=WrapUp_MF_LogIVREntry_Suffix.vxml&application.Logging_WriteLogEntry_NextDisconnectHandlerUri%24=WrapUp_DisconnectHandler.vxml&application.Logging_WriteLogEntry_NextErrorHandlerUri%24=WrapUp_ErrorHandler.vxml&application.WrapUp_LogIVREntry_LogMessage= 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 12
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 2
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_0_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_yes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_yes_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 14
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 5
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_writeToIvrLog.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 5
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_writeToIvrLog_DoIt.aspx dataSource=&database=WrapUpCodes&parameterCount=4&parameter_0=145&parameter_1=From_145_To_854_Menu_854_%230%2F69&parameter_2=Call%20entered%20wrap%20up%20call%20flow%3A%20145&parameter_3=C%3A%5CProgramData%5C3CX%5CData%5CHttp%5CInterface%5Civr%5CWrapUpCodes_Debug_86&password=wrapup&server=localhost&userName=WrapUpCodeUser 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 26
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 7
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_LogIVREntry_Suffix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 16
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 21
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_LogIVREntry_Suffix_DebugInfo.aspx application.WrapUp_LogIVREntry_LogMessage=Call%20entered%20wrap%20up%20call%20flow%3A%20145 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:20 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_inputWrapUpCode.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 5
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_inputWrapUpCode_ValidInput_DebugInfo.aspx WrapUp_inputWrapUpCode_Buffer=1&WrapUp_inputWrapUpCode_Result=ValidDigits 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 12
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 2
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_inputWrapUpCode_Valid_Input.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 5
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_inputWrapUpCode_Valid_Input_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 9
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_writeWrapUpCodeEntry.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 6
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_writeWrapUpCodeEntry_DoIt.aspx database=WrapUpCodes&parameterCount=2&parameter_0=145&parameter_1=1&password=wrapup&server=localhost&userName=WrapUpCodeUser 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 11
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_WriteLogFinished_Prefix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 5
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_WriteLogFinished_Prefix_DebugInfo.aspx application.Logging_WriteLogEntry_LogMessage=WrapUpCode%20callflow%20complete&application.Logging_WriteLogEntry_NextComponentUri%24=WrapUp_MF_WriteLogFinished_Suffix.vxml&application.Logging_WriteLogEntry_NextDisconnectHandlerUri%24=WrapUp_DisconnectHandler.vxml&application.Logging_WriteLogEntry_NextErrorHandlerUri%24=WrapUp_ErrorHandler.vxml&application.WrapUp_WriteLogFinished_LogMessage= 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 6
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 12
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 7
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Root_WrapUpCodes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 2
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_0_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_yes.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 1
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_isSqlLoggingOn_yes_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_writeToIvrLog.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 1
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/Logging_WriteLogEntry_MF_writeToIvrLog_DoIt.aspx dataSource=&database=WrapUpCodes&parameterCount=4&parameter_0=145&parameter_1=From_145_To_854_Menu_854_%230%2F69&parameter_2=WrapUpCode%20callflow%20complete&parameter_3=C%3A%5CProgramData%5C3CX%5CData%5CHttp%5CInterface%5Civr%5CWrapUpCodes_Debug_86&password=wrapup&server=localhost&userName=WrapUpCodeUser 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_WriteLogFinished_Suffix.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_WriteLogFinished_Suffix_DebugInfo.aspx application.WrapUp_WriteLogFinished_LogMessage=WrapUpCode%20callflow%20complete 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 9
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_MF_disconnectCallComponent1.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DisconnectHandler.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DisconnectHandler_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 8
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DH_conditionalComponent1.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DH_conditionalComponent1_0_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DH_conditionalComponent1_conditionalComponentBranch1.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 4
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DH_conditionalComponent1_conditionalComponentBranch1_DebugInfo.aspx - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 10
    2011-10-05 15:46:28 127.0.0.1 GET /ivr/WrapUpCodes_Debug_86/WrapUp_DH_exitCallflowComponent1.vxml - 5000 - 127.0.0.1 3CXIvrEngine/1.0+libwww/5.3.1 200 0 0 3
  2. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    From the ivr trace log
    Code:
    09:46:28.338|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.338|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.WrapUp_writeWrapUpCodeEntry_ScalarResult', ''''
    09:46:28.339|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.339|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.WrapUp_writeWrapUpCodeEntry_NonQueryResult', '0'
    09:46:28.340|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.340|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.WrapUp_writeWrapUpCodeEntry_QueryResult', '[]'
    09:46:28.340|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.341|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.341|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45417', ''
    09:46:28.341|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.341|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45417'
    09:46:28.342|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.342|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.343|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.343|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45417', 'true'
    09:46:28.343|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.343|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.344|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.344|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'server', 'project$_SqlServer'
    09:46:28.344|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.344|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'database', 'project$_SqlDBName'
    09:46:28.345|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.345|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'dataSource', ' '
    09:46:28.345|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'userName', 'project$_SqlUserName'
    09:46:28.346|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.346|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'password', 'project$_SqlPassword'
    09:46:28.346|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameterCount', '2'
    09:46:28.347|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.347|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_0', 'WrapUp_CallerID'
    09:46:28.347|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_1', 'WrapUp_inputWrapUpCode_Buffer'
    09:46:28.348|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.348|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'dataSource', 0x0BA6F510
    09:46:28.348|6356|(0):Subtag SBjsiGetVar. exiting: returned 2, 0x0BA6F510 (0x00000000)
    09:46:28.348|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'database', 0x0BA6F510
    09:46:28.349|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0193CB28)
    09:46:28.349|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameterCount', 0x0BA6F510
    09:46:28.349|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0193CB10)
    09:46:28.350|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_0', 0x0BA6F510
    09:46:28.350|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0193CB40)
    09:46:28.350|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_1', 0x0BA6F510
    09:46:28.350|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0193CAF8)
    09:46:28.351|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'password', 0x0BA6F510
    09:46:28.351|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018E27E0)
    09:46:28.351|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'server', 0x0BA6F510
    09:46:28.351|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018E27C8)
    09:46:28.351|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'userName', 0x0BA6F510
    09:46:28.352|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0192AFF8)
    09:46:28.375|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.375|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.376|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.376|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.377|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.377|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.377|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.378|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.378|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.378|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45421', ''
    09:46:28.378|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.379|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45421'
    09:46:28.379|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.380|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.380|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.380|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45421', 'true'
    09:46:28.380|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.381|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.381|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.381|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.WrapUp_writeWrapUpCodeEntry_ScalarResult', ''''
    09:46:28.382|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.382|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.WrapUp_writeWrapUpCodeEntry_NonQueryResult', '1'
    09:46:28.401|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.401|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.402|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.402|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.403|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.403|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.403|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.404|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45425', ''
    09:46:28.404|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.404|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45425'
    09:46:28.404|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.405|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.405|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.405|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45425', 'true'
    09:46:28.405|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.406|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.406|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.406|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_LogMessage', ''''
    09:46:28.406|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.407|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.WrapUp_WriteLogFinished_LogMessage', ''''
    09:46:28.407|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.407|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextComponentUri$', ''WrapUp_MF_WriteLogFinished_Suffix.vxml''
    09:46:28.408|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextErrorHandlerUri$', ''WrapUp_ErrorHandler.vxml''
    09:46:28.408|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.408|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextDisconnectHandlerUri$', ''WrapUp_DisconnectHandler.vxml''
    09:46:28.409|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_LogMessage', ''WrapUpCode callflow complete''
    09:46:28.409|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.409|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_LogMessage', 0x0BA6F510
    09:46:28.410|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018D08E0)
    09:46:28.410|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextComponentUri$', 0x0BA6F510
    09:46:28.410|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018D0868)
    09:46:28.410|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextDisconnectHandlerUri$', 0x0BA6F510
    09:46:28.411|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018D0838)
    09:46:28.411|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_NextErrorHandlerUri$', 0x0BA6F510
    09:46:28.411|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x01921FA8)
    09:46:28.411|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.WrapUp_WriteLogFinished_LogMessage', 0x0BA6F510
    09:46:28.411|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x01921FC0)
    09:46:28.435|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.436|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.436|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.437|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.437|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.438|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.438|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.438|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.438|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45429', ''
    09:46:28.439|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.439|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45429'
    09:46:28.440|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.440|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.440|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.441|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45429', 'true'
    09:46:28.441|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.441|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.441|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.459|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.460|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.460|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.461|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.461|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.461|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.462|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.462|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.463|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45433', ''
    09:46:28.463|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.463|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45433'
    09:46:28.464|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.464|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.464|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.464|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45433', 'true'
    09:46:28.465|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.465|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.465|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.486|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.487|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.487|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.488|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.488|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.488|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.489|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.489|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.489|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45437', ''
    09:46:28.489|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.490|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45437'
    09:46:28.490|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.490|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.490|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.491|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45437', 'true'
    09:46:28.491|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.491|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.491|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.509|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.509|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.510|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.510|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.511|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.511|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.511|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.511|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.512|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.512|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.512|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45441', ''
    09:46:28.513|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.513|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45441'
    09:46:28.513|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.514|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.514|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.515|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45441', 'true'
    09:46:28.515|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.515|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.516|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.516|6356|(0):Subtag SBjsiEval. entering: 0x01944FC0, 'EQUAL(project$_UseSqlLogging,'true')', 0x0BA6F50C
    09:46:28.516|6356|(0):Subtag SBjsiEval. exiting: returned 0, 0x0BA6F50C (0x01984D48)
    09:46:28.537|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.538|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.538|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.539|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.539|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.540|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.540|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.540|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.540|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45445', ''
    09:46:28.541|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.541|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45445'
    09:46:28.542|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.542|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.542|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.542|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45445', 'true'
    09:46:28.543|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.543|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.543|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.561|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.561|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.562|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.562|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.563|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.563|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.563|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.563|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.564|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.564|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45449', ''
    09:46:28.564|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.565|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45449'
    09:46:28.565|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.565|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.565|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.566|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45449', 'true'
    09:46:28.566|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.566|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.566|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.587|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.587|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.588|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.588|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.589|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.589|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.589|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.589|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.589|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.590|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.590|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45453', ''
    09:46:28.590|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.590|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45453'
    09:46:28.591|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.591|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.591|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.591|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45453', 'true'
    09:46:28.592|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.592|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.592|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.609|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.609|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.610|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.610|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.610|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_writeToIvrLog_ScalarResult', ''''
    09:46:28.611|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.611|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_writeToIvrLog_NonQueryResult', '0'
    09:46:28.611|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_writeToIvrLog_QueryResult', '[]'
    09:46:28.612|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.612|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.612|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.612|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45457', ''
    09:46:28.613|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.613|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45457'
    09:46:28.613|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.614|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.614|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.614|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45457', 'true'
    09:46:28.615|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.615|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.615|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.615|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'server', 'project$_SqlServer'
    09:46:28.616|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.616|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'database', 'project$_SqlDBName'
    09:46:28.616|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'dataSource', ''''
    09:46:28.617|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.617|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'userName', 'project$_SqlUserName'
    09:46:28.618|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'password', 'project$_SqlPassword'
    09:46:28.618|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.618|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameterCount', '4'
    09:46:28.619|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_0', 'session.ani'
    09:46:28.619|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.619|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_1', 'session.callid'
    09:46:28.620|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.620|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_2', 'Logging_WriteLogEntry_LogMessage'
    09:46:28.620|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, 'parameter_3', 'project$_WorkingDirectory$'
    09:46:28.621|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.621|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'dataSource', 0x0BA6F510
    09:46:28.622|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018DB228)
    09:46:28.622|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'database', 0x0BA6F510
    09:46:28.623|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018DB1E0)
    09:46:28.623|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameterCount', 0x0BA6F510
    09:46:28.623|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x018DB1F8)
    09:46:28.624|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_0', 0x0BA6F510
    09:46:28.624|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DF20)
    09:46:28.624|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_1', 0x0BA6F510
    09:46:28.625|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DF50)
    09:46:28.625|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_2', 0x0BA6F510
    09:46:28.625|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DF38)
    09:46:28.625|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'parameter_3', 0x0BA6F510
    09:46:28.626|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DFB0)
    09:46:28.626|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'password', 0x0BA6F510
    09:46:28.626|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DF68)
    09:46:28.627|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'server', 0x0BA6F510
    09:46:28.627|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x0199DF98)
    09:46:28.627|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'userName', 0x0BA6F510
    09:46:28.627|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x01932D48)
    09:46:28.651|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.651|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.652|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.652|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.653|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.653|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.653|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.654|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.654|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.654|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45461', ''
    09:46:28.654|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.654|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45461'
    09:46:28.655|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.655|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.655|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.656|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45461', 'true'
    09:46:28.657|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.657|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.657|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.657|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_writeToIvrLog_ScalarResult', ''''
    09:46:28.658|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.658|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.Logging_WriteLogEntry_writeToIvrLog_NonQueryResult', '0'
    09:46:28.659|6356|(0):Subtag SBjsiEval. entering: 0x01944FC0, 'Logging_WriteLogEntry_NextComponentUri$ != ''', 0x0BA6F50C
    09:46:28.660|6356|(0):Subtag SBjsiEval. exiting: returned 0, 0x0BA6F50C (0x019836D8)
    09:46:28.660|6356|(0):Subtag SBjsiEval. entering: 0x01944FC0, 'Logging_WriteLogEntry_NextComponentUri$', 0x0BA6F350
    09:46:28.660|6356|(0):Subtag SBjsiEval. exiting: returned 0, 0x0BA6F350 (0x019836C0)
    09:46:28.679|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.679|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.680|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.680|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.681|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.681|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.681|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.682|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45465', ''
    09:46:28.682|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.682|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45465'
    09:46:28.683|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.683|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.683|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.684|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45465', 'true'
    09:46:28.684|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.684|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.684|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.685|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, 'application.WrapUp_WriteLogFinished_LogMessage', 'application.Logging_WriteLogEntry_LogMessage'
    09:46:28.685|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.685|6356|(0):Subtag SBjsiGetVar. entering: 0x01944FC0, 'application.WrapUp_WriteLogFinished_LogMessage', 0x0BA6F510
    09:46:28.686|6356|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0BA6F510 (0x01984D48)
    09:46:28.708|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.708|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.709|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.709|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.710|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.710|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.710|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.710|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.711|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45469', ''
    09:46:28.711|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.711|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45469'
    09:46:28.711|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.712|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.712|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.712|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45469', 'true'
    09:46:28.712|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.713|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.713|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.732|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.732|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.733|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.733|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.734|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.734|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.734|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.734|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.734|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45473', ''
    09:46:28.734|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.734|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45473'
    09:46:28.735|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.735|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.735|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.735|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45473', 'true'
    09:46:28.736|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.736|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.736|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.750|6356|.\api\VXItelImpl.cpp(99):IvrDll, VXItelImpl::Impl::Disconnect(), Disconnect occurred
    09:46:28.751|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.751|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.751|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.752|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.752|6356|(0):Subtag SBjsiSetVarValue. entering: 0x01944FC0, '_event', 0x0193CB70
    09:46:28.753|6356|(0):Subtag SBjsiSetVarValue. exiting: returned 0
    09:46:28.753|6356|(0):Subtag SBjsiSetVarValue. entering: 0x01944FC0, '_message', 0x0193CB40
    09:46:28.772|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.773|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.773|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.774|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.774|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.774|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.775|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.775|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.775|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45477', ''
    09:46:28.776|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.776|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45477'
    09:46:28.776|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.776|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.776|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.776|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45477', 'true'
    09:46:28.776|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.776|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.777|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.801|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.801|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.802|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.802|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.803|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.803|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.803|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.803|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.804|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.804|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45481', ''
    09:46:28.804|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.804|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45481'
    09:46:28.805|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.805|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.805|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.805|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45481', 'true'
    09:46:28.806|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.806|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.806|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.824|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.824|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.825|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.825|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.826|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.826|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.826|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.827|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.827|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45485', ''
    09:46:28.827|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.827|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45485'
    09:46:28.828|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.828|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.828|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.828|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45485', 'true'
    09:46:28.829|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.829|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.829|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.829|6356|(0):Subtag SBjsiEval. entering: 0x01944FC0, '1 == 1', 0x0BA6F50C
    09:46:28.830|6356|(0):Subtag SBjsiEval. exiting: returned 0, 0x0BA6F50C (0x0193CAE0)
    09:46:28.853|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.853|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.854|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.854|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.855|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.855|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.855|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.855|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.856|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.856|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.856|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45489', ''
    09:46:28.856|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.857|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45489'
    09:46:28.857|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.857|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.857|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.858|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45489', 'true'
    09:46:28.858|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.858|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.858|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.876|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.876|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.877|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.877|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.878|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.878|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.878|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.878|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.878|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.879|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.879|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45493', ''
    09:46:28.880|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.880|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45493'
    09:46:28.880|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.880|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.881|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.881|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45493', 'true'
    09:46:28.881|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.881|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.882|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.904|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.905|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.905|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.906|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.906|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.906|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.907|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.907|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.907|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45497', ''
    09:46:28.908|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.908|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45497'
    09:46:28.908|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.908|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.909|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.909|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45497', 'true'
    09:46:28.909|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.909|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.910|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.927|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.927|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.928|6356|(0):Subtag SBjsiPopScope. exiting: returned 0
    09:46:28.928|6356|(0):Subtag SBjsiPopScope. entering: 0x01944FC0
    09:46:28.929|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'document'
    09:46:28.929|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.929|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'dialog'
    09:46:28.930|6356|(0):Subtag SBjsiCreateVarExpr. entering: 0x01944FC0, '$_internalName_45501', ''
    09:46:28.930|6356|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    09:46:28.930|6356|(0):Subtag SBjsiCheckVar. entering: 0x01944FC0, '$_internalName_45501'
    09:46:28.931|6356|(0):Subtag SBjsiCheckVar. exiting: returned 1
    09:46:28.931|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, 'local'
    09:46:28.931|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.931|6356|(0):Subtag SBjsiSetVarExpr. entering: 0x01944FC0, '$_internalName_45501', 'true'
    09:46:28.932|6356|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    09:46:28.932|6356|(0):Subtag SBjsiPushScope. entering: 0x01944FC0, '$_execAnonymous_'
    09:46:28.932|6356|(0):Subtag SBjsiPushScope. exiting: returned 0
    09:46:28.933|6356|(0):Subtag SBjsiDestroyContext. entering: 0x01954174 (0x01944FC0)
    09:46:28.935|6356|(0):Subtag SBjsiDestroyContext. exiting: returned 0
    09:46:28.936|6356|(0):Subtag SBjsiDestroyContext. entering: 0x01954074 (0x0193FB60)
    09:46:28.937|6356|(0):Subtag SBjsiDestroyContext. exiting: returned 0
    09:46:28.937|6356|(0):Event occurred (ID # 1).
    09:46:28.937|6356|.\VXIMachine.cpp(385):IvrDll, CallSession::PromptsMap::WaitPlayed(), Waiting for prompts (start)
    09:46:37.961|5392|.\VXIMachine.cpp(1281):IvrDll, CallSession::PromptPlayed(), Prompt 2 played
    09:46:37.961|5392|.\VXIMachine.cpp(338):IvrDll, CallSession::PromptsMap::PromptPlayed(), All prompts played
    09:46:37.961|6356|.\VXIMachine.cpp(398):IvrDll, CallSession::PromptsMap::WaitPlayed(), Waiting for prompts (stop)
    09:46:37.962|6356|.\api\VXItelImpl.cpp(83):IvrDll, VXItelImpl::Impl::EndSession(), EndSession
    09:46:37.962|6356|(0):Subtag VXIplatformProcessDocument. exiting: rc = 0, 0x00000000
    09:46:37.962|6356|(0):Subtag ChannelThread. NULL result
    09:46:38.962|6356|.\PbxMedia\IVREngine.cpp(999):IvrService, IVREngine::IVRCallListener::SessionFinished(), (0)IVR session has been finished for established call from 145
    09:46:38.962|6356|.\VXIMachine.cpp(1776):IvrDll, VXIMachine::EndSession(), Removing From_145_To_854_Menu_854_#0/69 call
    09:46:38.962|6356|(0):Subtag SBjsiDestroyResource. entering: 0x0193D36C (0x018F4440)
    09:46:38.963|6356|(0):Subtag SBjsiDestroyResource. exiting: returned 0
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Sure, send me the project in a private message and I'll take a look at it.
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Can't do a file attachment in private message. Where is the option?
