VAD time controle
Discussion in 'Call Flow Designer' started by schiphorst, Jun 1, 2017.
  1. schiphorst
    Oct 13, 2016
    9
    In a earlier post there is question about time controle in the VAD v15.
    Now in the controle the is a C#: DateTime.Now.Hour >= 9 && DateTime.Now.Hour < 12
    This is from 9 till 12, i whant to set is from: 8:30 till 12:29 how do i get the minutes?
    i whant to make three controles:
    8:30 till 12:29
    12:30 till 12:59
    13:00 till 17:00
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,254
    97
    Hi @schiphorst,
    The expression is a bit longer, but it's the same concept, it's a C# expression that returns true when the condition is met. So for example, an expression that returns true between 8:30 and 12:30 would be:
    (DateTime.Now.Hour == 8 && DateTime.Now.Minute >= 30) || DateTime.Now.Hour == 9 || DateTime.Now.Hour == 10 || DateTime.Now.Hour == 11 || (DateTime.Now.Hour == 12 && DateTime.Now.Minute < 30)
    You can apply the same concept for the other ranges you have.
    Kind regards.
  3. schiphorst
    Oct 13, 2016
    9
    Thank you for your responds, i will try it.
    How do i set the days of the week?
    greatings,
  4. edossantos
    Jun 27, 2007
    1,254
    97
