Vad12 Licence and Passive toolbax
Discussion in 'CRM / Helpdesk / App Integration' started by hakana, Aug 27, 2014.
  1. hakana
    Aug 27, 2014
    5
    i downloaded vad2 version and activate license, but except "Call Related" toolbox items, others (Control Structures, Advanced) disabled, how can they be enable ?
    and also i downloaded vad12 which is new version and install, it has also passive toolbox items and i can't activate licence in it. I try to applied http://www.3cx.com/forums/help-licence-is-suddenly-not-working-37903.html solution but did not work.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there!
    Are you activating a VAD license? Or a general 3CX license?
    The VAD is a product licensed separatedly, so you need to purchase a VAD license for it. Please confirm if this is your case or not.
    Kind regards.
  3. hakana
    Aug 27, 2014
    5
    Sorry, i used my 3cx licence but vad accepted it, how it can be ? :)
  4. VAD_Support
    Aug 6, 2009
    690
    Yes, the activation procedure doesn't give any error, but if the key doesn't belong to the VAD the licensed features are not activated. You need to buy a VAD license to work with this tool.
    Kind regards.
  5. hakana
    Aug 27, 2014
    5
    Ok, Thanks...
