Validate record VAD (press 1 to record or press 2 to repeat)
Discussion in 'CRM / Helpdesk / App Integration' started by hector-ip, Oct 25, 2012.
  1. hector-ip
    Mar 21, 2012
    Hello, sorry for my bad english;)
    I have an IVR where the customer record several conversations, but wanted to hear before saving the file on your hard disk.
    Something like:
    Recording> recording played> press 1 to record or press 2 to repeat
    and not written to disk until the conversation validate.
    Current flow capture
    regards
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Re: Validate record VAD (press 1 to record or press 2 to rep
    Hello Hector,
    In order to do this, you need to configure your Record component to save the file. Once you have recorded the audio, you can play it back to the user and ask him/her to confirm to save or discard the recording. If the user decides to save it, then the file is already on disk. If the user decides to discard it, then you need to delete the audio file. To delete a file you will have to use an External Code Execution component and create a DLL that does the job, as currently there is no component to manipulate files that way, only read and write operations on files are allowed with the File Magement component.
    To play the recording back to the user, you need to use a Prompt of type RecordedAudioPrompt, and set the AudioId property to the value of your recordComponent1.AudioId.
    Hope the information helps, and let me know if you have any other question.
  3. hector-ip
    Mar 21, 2012
    Thank you!
    Today when I have a moment, I will make tests and confirm you;)
    Regards
