Variable concatenation
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 1, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I want to take a variable and assign it to another variable with a string concatenated to it.
    How would I do that?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You can use the variable assignment component, using the "CONCATENATE" function in the expression editor.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Thanks, I missed that.
