Variable order
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Mar 17, 2010.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    When passing in variables to a .net library, how does it determine the order of the variables?
    I have 5 variables in a code component, and I have them in the same order in my vad component and with the same names, but they're getting passed in to the function in a different order.
  2. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Looks like variables are actually passed in, inreverse order.
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Variables are passed to the library in the same order specified in the configuration of the component. Can you send me the callflow file to review it? I have tested this here and works, so maybe there is something wrong in the configuration...
    Thanks,
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What I did was I attached the Visual Studio debugger to the IIS worker process and the variables always came in the opposite order that they were specified in the VAD designer.
    However it only did this for is one component, which is odd.
    I will send you the files so you can take a look.
    Should I just attach it here to a private message?
  5. VAD_Support
    Aug 6, 2009
    690
    Yes, please attach it to a private message, so I can take a look at it.
    Also, can you send me the generated ASPX output for the component? That way I can see if variable order is right in code, or if it has been changed there...
    Thanks.
  6. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    OK, I will get this to you later this evening.
  7. VAD_Support
    Aug 6, 2009
    690
  8. VAD_Support
    Aug 6, 2009
    690
    Hi Shahzad,
    I've been looking at the files you sent me, and doing some testing with the VAD, and it seems that variables are passed to the external component in alphabetical order. This is a bug in the VAD that we'll fix as soon as possible.
    Until we release this fix, something you can do to avoid having this problem is renaming the parameters, for example adding a prefix in alphabetical order ("p01_", "p02_", etc.). This way, parameters will be passed in the order you need.
    Thanks for reporting this error, we'll work on a fix and maybe in a couple of weeks we can release a new version...
  9. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Thank you
