Various Issues
Discussion in '3CX Phone System - General' started by TerryJoyce, Apr 15, 2011.
  1. TerryJoyce
    Apr 15, 2011
    11
    Hello All in advance of help.
    I am new to setting up the 3CX system and have decided to take on the challenge of doing so. I have managed to get lots of things working with the phone system. However, there are a few things that allude me in a successful deployment.
    First, whenever an extension reboots it does not sync back to the server and no one can dial in until the phone is dialed out. Just wondering what can cause this issue.
    Second, I am using Cisco SPA 508 phones. I would like to put custom speed dials on handsets denoted by the user. However when the phone reboots itself the speed dials stay. But when I reboot using the 3CX software they all disappear. Is there anywhere on the 3CX system I can set these for the users??
    Just to let you know about my setup. I have a Juniper firewall (I think I have opened all the ports and routed them to the server), I also have the 3CX server and the Cisco 508G.
    Thanks for all the advice in advance.
    Terry
    11,293
    361
    It sound like you have the phones set-up to auto provision with each reboot and the provisioning file is not written to provision the set correctly.
    Same thing.
  3. TerryJoyce
    Apr 15, 2011
    11
    Leejor,
    Thanks for this. I am only using the standard config that comes with 3CX is there no way in the interface to setup those buttons???
    Terry
  4. TerryJoyce
    Apr 15, 2011
    11
    Thanks for the help. I have decided to setup custom templates for each user to allow them to setup there own speed dials.
    Terry
  5. netswork
    netswork Active Member
    Mar 11, 2011
    577
    You can either auto provision your phones or manually configure your phones from the phones web interface. If you want to manually configure the phones then you need to remove the provisioning URL from the web interface of the phone. That is why when the phone reboots the configuration is being removed as noted by Leejor.
    If all you want is simple speed dial's and BLF's the provisioning configuration from 3cx should work for you. Just configure the extension in 3cx and then re-provision the phone.
