VCEHost.exe not starting
Discussion in '3CX Phone System - General' started by pratikdbl, Apr 3, 2011.
  1. pratikdbl
    Jan 23, 2011
    Dear All,
    I am using 3CX PhoneSystem 9 with all the updates till now. It was working Ok till yesterday but suddenly today there was some problem in voice. It was not so clear. Later, queue manager stopped and refused to start again. Later, I restart my system. At the start it showed VCEHost.exe encountered some problem. And then may be due to this, queue manager also doesn't start.
    If anybody has any idea about his please share.
    Pratik
  2. brunosvo
    Feb 24, 2012
    I see this topic is old, but I'm having the same problem reported.
    Has anyone seen this problem? Or the user who opened this topic has already solved?
