Vega 50 Europa-4FXO Standard support
Discussion in '3CX Phone System - General' started by EmadFayed, Oct 7, 2008.
  1. EmadFayed
    Sep 30, 2008
    dear all
    is 3cx supporting this gateway
    please i need answer
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
  3. EmadFayed
    Sep 30, 2008
    the 3cx say
    that it support 2 model Vega 50 europa the first one is 2fxo-4fxs
    and the seconde is 2 BRI
    but no information about 4fxo model
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I think it will be the same try it and you'll see
  5. luislombard
    Jan 30, 2015
    Hello there!
    I'm trying to configure a Vega50 4FXO with 3CX, the manufacturer provides some templates but they look to work only with previous versions of 3CX (http://wiki.sangoma.com/Vega-3CX-Guide) does some one knows how to configure it to work with 3CX 12.5?
    Thank you for your time.
  6. El-Rada
    Feb 18, 2016
    Does anybody figured out how to make it work on 3CX 14? SAme issue with a Sangoma A200.
