Vegastream 8FXO not hanging up calls
Discussion in '3CX Phone System - General' started by adetterer, Mar 16, 2009.
  1. adetterer
    Aug 28, 2007
    22
    I've setup a Vegastream 8FXO successfully with 3CX.
    The issue I am having with it is:
    If I call in once and hang up the call doesn't disconnect so the phones will keep on ringing for 20ish seconds.
    If a call goes into voicemail 3CX/vegastream keeps that line open on 999 until I manually go in and disconnect it.
    I don't think it is getting the disconnection signal or something?
    Any light on this topic?
  2. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    I dont know much about Vegastream kit but we have had a similar issue with Patton hardware reported by some of our resellers.
    Our solution was to lower the "Loopbreak Detection" to 200ms, I dont know where this setting is on a Vega but I'm sure your supplier should be able to help you out there.
    Regards,
    Emmet.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    I suggest contacting Vegastream for this. They should be able to tell you how to configure the device to detect the call hang up....
