Vegastream ISDN BRI gateways
Discussion in '3CX Phone System - General' started by steve_d, Aug 20, 2007.
  1. steve_d
    Aug 20, 2007
    Do these work with 3cx?
    The 3cx website mentions Vegastream (as a supplier of VOIP gateways) but there are no Vegastream products on the supported gateways page?
    Thanks in advance
    Steve.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please be consider that to use the support gateway such as PATTON and etc ... Since those hardware had been tested by 3CX. Therefore, those hardware should be fully integrate with 3CX system.
    https://www.3cx.com/support/
  3. jwmol
    Jan 5, 2008
    Vegastream BRI gateway
    More mysteriously, on the v2.0.1245.0 release notes:
    Added support for Vegastream gateways
    Anyone that knows the story?
