Ver 1.3.4 Audio Problems Onda TQ150
Discussion in 'Android' started by Gabriele, Apr 10, 2012.
  1. Gabriele
    Oct 12, 2011
    13
    Hi, I have a problem with Onda TQ150 and 3CX phone ver 1.3.4 and our 3CX PBX.
    The phones connects correctly to PBX and I can make and receive calls, but the audio still remains on speaker also if I select earpiece, so the program is almost unusable..
    Isn't this problem http://www.3cx.com/forums/v1-3-3-using-rear-speaker-22402.html because it never works, neither the first time
  2. Ozyank
    Jun 1, 2012
    I am having the same problem with iPhone 4S. Earpiece was working on iPhone 4.
