ver. 1.3.4: no address book seen
Discussion in 'Android' started by alpa, Apr 4, 2012.
  1. alpa
    Apr 4, 2012
    Hi! I have a weird issue. I do not see the address book from the 3CX 1.3.4 for Android (2.34, Experia Mini, build 4.0.2.A.0.62). After just installed the program, I could see and dial numbers from the phone's address book. However, couple of days later this disappeared. When pressed "contacts" button, says "No contacts", and "search contact" does not return anything. Any ideas?
    Thanks in advance!
