Ver 2.0.0
Discussion in 'Android' started by Dennis, May 25, 2012.
  1. Dennis
    Aug 15, 2011
    The new version 2.0.0 for Android has become available on the play store.
    However i cannot get it to connect on 3g always says no network. I had
    ver 1.3.4 installed and that functioned perfectly so there is no fault with my setup.
  2. 12494
    12494 Member
    Apr 16, 2010
    292
    25
    Just checking here to see what others found and I found your post.
    I have the same experience. My 1.3.4 version worked fine. Now I get NO NETWORK whether trying to go wireless or wifi.
    Allen
  3. phxlad
    Mar 24, 2008
    13
    I am using LG-999 and not that I version 2.0.0 I can only connect using WIFI. When I have good 4g coverage I still get "No Network" so if ANYONE has solution please post it.
  4. Dennis
    Aug 15, 2011
    Ok Ver 2.0.1 sorts out the 3g issue. Over all seems like a much
    better build than Ver 1.3.4 havent had the phone unregistering
    in the backround while the dot stays green once the whole day.
    Registers perfectly from 3g to wifi and back again. Is there
    a reason we cant use the G729 codec with a 3cx System?
  5. Gabriele
    Oct 12, 2011
    13
    Hi, I have a problem on my Motorola Defy. I've upgraded to 2.0.1 version, but now I'm unable to connect with 3CX tunnel. It stays on registering and nothing changes.. Without tunnel is ok. What could be the problem?
  6. Gabriele
    Oct 12, 2011
    13
    I've solved the problem. You have to uninstall 3CX, reboot the phone and then reinstall..
  7. StefanW
    Jun 2, 2009
    1,210
    85
    G729 is a payed codec and we cant sent it out for free...
