Ver 7 to Ver 11 upgrade
Discussion in '3CX Phone System - General' started by sunergon, Jul 25, 2013.
  1. sunergon
    Jul 25, 2013
    I've purchased the relevant upgrade and according to this forum post "http://www.3cx.com/forums/how-to-upgrade-from-v8-to-v10-20670.html" need to follow this path:
    1) Upg to Ver 9 - take a backup
    2) Apply Ver 9 Sp5 - take a backup
    3) Install Ver 11 and do backup restore.
    I definitely don't want to do a fresh setup after installing Ver 11 so DO want to follow the recommended path
    BUT where do I get install files for Ver 9, Ver 9 SP5 ??
  2. sunergon
    Jul 25, 2013
    Problem solved !
    3CX System updates takes care of it from inside the Management Console - very well done :) !
