ver 9**General Question Backup
Discussion in '3CX Phone System - General' started by rico06, Jul 16, 2010.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    sorry but I have a simple qustion
    is the version 9 is now on production ad not anymore beta?
    can I use it with my license corporate?
    thanks
  2. carolinainnovative
    May 4, 2009
    369
    6
    Re: ver 9
    License: yes - your v8 license should work as long as you have upgrade insurance.
    Production: sort-of - it is out of beta but is still in "release candidate" mode - so it is still "use at your peril" - but lots of folks are using it in production without major issues.
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Re: ver 9
    great thank you
    It was not really clear , when you look to download upgrade there is the two version
    I might test it soon.
    can you tell me if importing form version 8 will be complete
  4. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Re: ver 9 welcome mail
    ok I install V9 on a test pbx
    No prob exept on the welcome mail, I receive the link on the remote user but with the local IP adress instead ok the public IP (or public domain)
    did I missed something on the setting ?
  5. carolinainnovative
    May 4, 2009
    369
    6
    Re: ver 9
    I would assume a pbx administrator is sharp enough to know whether or not he/she has purchased upgrade insurance.
  6. carolinainnovative
    May 4, 2009
    369
    6
    unfortunately i hear the provisioning emails only work in-house - so local IP only. I've asked for them to give us some more flexibility with that email but so far it hasn't happened.
  7. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Re: ver 9
    it is not a big problem if the provisioning is not working for the external wan extension, it is easy to set it oup manually
    the problem is that the call assistant doesnt work outside the lan (set up maually)
  8. carolinainnovative
    May 4, 2009
    369
    6
    Re: ver 9
    Make sure you clicked the button to put it in remote mode OR use 3cx Tunnel. Both work quite well as I use it outside my network quite often.
  9. rico06
    rico06 New Member
    Jan 11, 2008
    143
    Re: ver 9
    thanks Salter
    I was the button needed to be push to use or not the tunnel on the assistant
    for the phone I need to make some more test of quality, after few setting change I did not restart all the services before testing the call
    The last thing is now to mahe the cam work.
    yesterday my configuration was two laptop connect with tunnel but on the VPN (I know tunnel was not necessary)
    I have now two test to make:
    1 cut the VPN and test withe tunnel on
    2 VPN active, juste connection LAN without tunnel
  10. carolinainnovative
    May 4, 2009
    369
    6
    Re: ver 9
    I do not believe the "update" button magically updates you to the newest VERSION - just updates within the current version. To change from v8 to v9, you have to uninstall and reinstall - and if you're going through all that trouble, its your own dern fault if you didn't check your license first! :p
  11. carolinainnovative
    May 4, 2009
    369
    6
    Re: ver 9
    I don't need to verify, although I'm sure 3cx support will chime in here in about 4 or 5 more hours (monday work hours in Cyprus).
    v8 -> v9 is a major upgrade, like most 3CX major version changes. Allowing for a click-to-upgrade setup would bring in a host of other issues they haven't even had us beta testers testing. Major version changes are uninstall->reinstall. Minor version changes can be auto-updated.
  12. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    99
    Re: ver 9
    As Salter said,
    For V7 to V8 or V8 to V9 upgrades you need take a backup of your system using the 3CX Backup tool, uninstall the old PBX, install the new one and restore your backup.
    We do a lot of tests to ensure that these upgrades work as smooth as possible for 3CX users.
    Now the "Upgrades" page you see in the management console are just "Minor upgrades" to the phonesystem it's self. You could download a fix for Caller ID issues, or a fix for a crashing management console for example. But you can never automatically upgrade from v8 to v9 with it.
    Upgrading from V8-V9 has never been so reliable before, so i'd go ahead with the upgrade. So far no one has compained about the V8-V9 upgrading system so i'd go ahead with it.
