VER v2.0.1361.0 UPGRADE SHOWS OFFLINE
Discussion in '3CX Phone System - General' started by garydtg, Feb 8, 2007.
  1. garydtg
    Jan 16, 2007
    upgraded to new version now the system shows off line..... what did i miss? :?
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Try restarting the machine to see if the services the software uses load normally on startup, and if the problems persists please send us the logs on support@3cx.com .
  3. garydtg
    Jan 16, 2007
    i did try restarting the system several times. somtimes the ivr service would start and other times it would not.... i did find someone having the same problem.... they uninstalled the program and reinstalled it..... it now works fine. i think somthing may be missing in the upgrade process.
  4. xc99tour
    Jan 2, 2007
    37
    Don't feel bad. I had the same problem and ended up having to re-install. I don't think 3CX took me serious either.
  5. Costas3CX
    Jan 23, 2007
    217
    For this type of issue we require the log files. You can find them on C:\Program Files\3CX PhoneSystem\Data\Logs . An email at support@3cx.com containing the log files will give us more to work with to understand the problem you were faced with.
