verifying recorded names in the system
Discussion in '3CX Phone System - General' started by egiblockDM, Jul 15, 2013.
  1. egiblockDM
    Apr 22, 2013
    39
    for the recorded names and company directory to work, the person has to record their own name..
    why not just use the first 3 letters or so out of the name that is typed in the extension??????
    is there a way to verify the letters that the system recognizes currently ?
    we have one user in the system that the 3cx can't find when someone searches by name.
    thanks
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    because if you have 3 people with these names
    John Smith
    Jeff Smithson
    Joane Smint
    If you dial 764 it needs to say
    For John Smith, press 1
    For Jeff Smithson, press 2
    For Joane Smint, press 3
    It does this in their voice, as dialects and pronunciations of NAMES is not easy to replicate with automation. Thus, it uses the recorded named.
    However, the "###" uses the actual name in the extension setup for name matching as far as I know - but they have to have their voice name recorded as well.
