Verizon as the Voip provider?
Discussion in '3CX Phone System - General' started by madbenny, Oct 4, 2013.
  1. madbenny
    Oct 4, 2013
    I'm looking to possibly using 3CX as our phone system but first I need to know if Verizon is a supported. Currently we have Verizon Voip coming in on a T1 line and then converted back to POTs lines through an Adtran Total Access 924.
    Thank you in advance.
    John
    11,079
    324
    In theory, it should work, it's just a mater of configuring 3CX properly.
    If you don't feel confident in trying this out yourself, and, you can try connecting the Free version as a trial, then i would suggest contacting a local 3CX Partner, who is probably familiar with interfacing the PBX to Verizons service.
    Forgot to add...you will probably require a T1 to SIP gateway.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Based on reading Verizon's VoIP IP Trunking page: http://www.verizonenterprise.com/solutions/public_sector/federal/contracts/wits3/products/voice/voip_trunking.xml
    They say it is "designed to work with any IP PBX that supports SIP-based trunking".. which would mean the 3CX IP PBX.
    If that is the service you have, it will work.
    If not, mileage varies.. likely not work.
    Comcast, for example, does do VoIP.. but not to SIP specs which you can get connected to an IP PBX.
    If somebody has something with Comcast working to the contrary.. please let me know. Running a SIP trunk over Comcast is horrible which we won't support..
    Verizon says it has access via T1, so it can work with their circuitry options.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    We run sip trunks voice traffic over Comcast with no issue as long as you have a 2nd modem just for the voip trunks.
    As far as Verizon is concerned consider looking at other options because even if you want to use Veirzon as your carrier still they are not the best deal on the block!
  5. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,564
    237
    @madbenny
    In your current configuration it looks like Verizon is supplying analog (POTS) lines to your current system. This is supported in 3CX with the appropriate analog gateway. However, if you want digital features (DIDs for instance) you would need to get Verizon to deliver your voice via PRI or SIP. PRI is supported in 3CX with the appropriate gateway as well. SIP is not on the officially supported list, but most of the time it is the provider that will give you grief over that, 3CX plays nice.
    @ian.watts
    Just FYI, Comcast does offer true SIP trunks now, but not out here in the west coast yet. And 3CX is not on the supported PBX list but I'm working with some Comcast folks I know to try and get it there.
    http://business.comcast.com/smb/services/phone/sip-trunks
