Version 12 issue when installing the Myphone client
Discussion in '3CX Phone System - General' started by netforcejames, Sep 3, 2013.
  1. netforcejames
    Sep 3, 2013
    After just installing Version 12 I only found the option to use Abyss as a web server, and I don't know how to install the Myphone client with Abyss. I have set up and configured almost a dozen 3CX systems now, but they all used IIS which I specify http://PBXIP:5000/myphone to set up the Myphone client.
    After reviewing all the online videos and trying their suggested info I am stumped as how to set up the Myphone client using Abyss, does anyone have any advice on this issue? Thanks in advance
  2. tom_ch
    Jul 6, 2011
    69
    You can not install it, because theres is no MyPhone in v12.
    Please read through the Blog posts about v12.
    MyPhone is now integrated into 3CX Phone.
  3. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    That is correct. The Myphone features are now intergrated into 3CXPhone for Windows. Please let us know if you have any further questions or inquiries.
    Best Regards
