Version 14 and STUN Server
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 11, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Port Forwarding is setup
    In the settings - network - public IP - STUN Server under the entry
    STUN Disabled (Not Supported) does this mean STUN is not supported
    What is the down side if I enable it
    The static Public IP will not take a FQDN and if I have an Internet Service with a Dynamic Public IP which changes - so when it changes what will happen
    10,758
    286
    I have to assume that it means that in V14, STUN is not considered necessary as you are expected to have a static Public IP.
    STUN is used to determine that type of NAT you are behind and your public IP. If calls to a provider use an IP that you datafilled, but has since changed, then external calls will not work properly. If 3CX relies on a STUN server to determine the current public IP, then it would be kept up to date, if, and when it changed.
    I'm assuming that you will have issues as you had previously, no audio, or no calls at all.
  3. petewatterschats
    Jan 19, 2016
    151
    Thanks for the information.
    I will enable the STUN Service since there does not seem to be a down side
