Version 15.5
Discussion in 'Ideas' started by aditel, Aug 25, 2017.
  1. aditel
    Dec 2, 2015
    23
    In version 14 under "phones" you have the port information on the phones. But on V15.5 the ports of the provisioned phones do not appear on the Phones node on the PBX side. Can you implement it also in version 15.5 and forward?
    BR
    Roger
