Version 3.1 Build 2434 3rd August 2007 uploaded
Discussion in '3CX Phone System - General' started by kevin, Aug 3, 2007.
  1. kevin
    kevin Member
    Nov 23, 2006
    316
    This build can be upgraded from previous versions, and a very brief summary of changes is listed hereunder.
    http://www.3cx.com/downloads/3cxphonesystem31.exe
    Build version 3.1.2434 3rd August 2007 - Maintenance Release
    Improved Vista support - Microsoft Windows Vista is now fully supported
    System can now be configured to listen on specific interfaces / address (internal or external) in the system's INI file
    Improved download mechanism for updating of languages, prompts, and templates
    Interface now also available in the following languages: Italian, German, Spanish, Greek, Danish
    Manual now also available in the following languages: Italian, German, Spanish, French
    Fixed signaling to handle header translation carried out by Cisco NAT devices
    Added configuration templates for PATTON / INALP gateways (ISDN BRI)
    Several bug fixes
    ____________________
    Kevin Attard Compagno
    http://www.3cx.com
