Version 5.1 typo?
Discussion in '3CX Phone System - General' started by zensoftware, Feb 15, 2008.
  1. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    When choosing which codecs are to be used for a SIP provider. if you click on the more link you get
    "Specify which codecs to use and according to which priority More > Codecs are used to encode audio. 3CX supports free codecs such as G711 alaw and mlaw, GSM and Speex. G729 or G723 are not supported since they requires royalties, and furthermore GSM is just as good. "
    Should this not be changed for version 5 ;)
    Cheers
    Neil
