Version 5 upgrade internal call functionality
Discussion in '3CX Phone System - General' started by ihasham, Dec 4, 2007.
  1. ihasham
    Dec 4, 2007
    I have 3CX Version 3 and I (luckily) backed up the database and upgraded to Version 5 RC2.
    It then did the following:
    - Incoming calls from VoipTalk (SIP Provider) failed intermittently (works after reboot but fails after 5 minutes later) but Sipgate worked perfectly. :x
    - Calls between extensions failed.
    I uninstalled the software, reinstalled it and added two extensions, configured on two PCs and test calls and I get an error.
    It did respond as previously.
    I then downgraded to Version 3 and it sorted the problem out! :D
    I am now back to Version 3 but I WANT to get through to Version 5 as it has fax capabilities which I need!
    Btw, I am installing this very soon at a client site.
    I am installing this software on a Server with Windows 2003 Server x64.
    Please help me get over this ordeal as soon as possible.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Can you please provide log of this failure.
