Version 8
Discussion in '3CX Phone System - General' started by rico06, Oct 18, 2009.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    juste to be sure, the version 8.9414 is the final release ???
    Is someone test already on a W2003 R2 with exchanger server 2007 UM on the same system.
    Thanks for your feedback, I don't want any trouble ...
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    It was, the current version is 8.0.9532 which fixes a registration issue with a specific provider if I recall correctly.
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    thank you for your feedback, I'm going to update it today
