Vesion/Updates page fails to load
Discussion in '3CX Phone System - General' started by jparisi, Dec 7, 2007.
  1. jparisi
    Oct 1, 2007
    92
    Clicking on the Versions/Updates link I get "Cannot find server. Aquiring data failed. Please try again later"
    Tried for a few days, always the same.
    In the beta od 4 we were playing with this would bring up a page that said there were no updates available.
  2. JamesC
    Dec 5, 2007
    20
    Can you ping http://www.3cx.com from the server? (I assume the update service goes to the main website).
  3. jparisi
    Oct 1, 2007
    92
    Yes, I can get to the main site with no problem
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    Had the same problem in build 3563.
    After installing 3648 it works fine.
    Have you upgraded?
  5. jparisi
    Oct 1, 2007
    92
    Yes, I've upgraded to the final version and it still will not load.
