VIDEO CALL THROUGH 3CX
Discussion in '3CX Phone System - General' started by aatiph, Sep 10, 2009.
  1. aatiph
    Sep 10, 2009
    5
    Dear Buddies, I am trying to make Video Call / video phone (Mirial / IVE/ Polycom) to register with my 3CX (FREE VERSION) and use to make SIP Video calls, but my Softphones are not registered with it. I am using both Public and Private IPs
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    you use soft or hard phone ? -> I am trying to make Video Call / video phone (Mirial / IVE/ Polycom)....Softphones are not registered with it.
    wath softphone are you using ? 3cx softphone can't make vidéocall. but you can use bria, to make this.
  3. aatiph
    Sep 10, 2009
    5
    Do 3CX VOIP phone system support Video Calls? I am trying to use Polycom PVX and Mirial Softphone which are SIP Based, and when I give the SIP setting, it shows registered.... but when I tried to make call it do not allow to make call. we have tested the 3CX IP Phone which are working fine. I have place the System on Public IP.
  4. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I think you have to un-check PBX Delivers audio for it to work.
    I remember reading something along those lines on the forum not long ago.
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    in fact you must uncheck pkb deliver audio and Support 'Replaces' header, and Supports Re-Invite must be check.
  6. aatiph
    Sep 10, 2009
    5
    I cant find these settings, can you guide me under which tab I will find these settings
  7. tpinnovations
    Jul 30, 2009
    296
    VoIP Providers > VoiP Provider > Advanced Tab
  8. aatiph
    Sep 10, 2009
    5
    Dear Buddy, I don't have this setting VOIP Provider > Voip Provider > Advance
    I have only one TAB for VOIP Provider which allow to choose any of VOIP provider from list, since I am not using any External Source for calling, I am just trying it for my own extension based Video Conference. Please comment! also do you have any other Windows Based VOIP PABX or Video Calling server in your mind to test
  9. aatiph
    Sep 10, 2009
    5
    I am using the FREE WARE of 3CX
  10. tpinnovations
    Jul 30, 2009
    296
    Go to Extension > Extension # > Other Tab
    Make sure the following are set;
    PBX Delivers Audio - Unchecked
    Supports Re-Invite - Check
    Support 'Replaces' header - Unchecked
