Video Calling Problems
Discussion in '3CX Phone System - General' started by stevodevo, Aug 17, 2010.
  1. stevodevo
    Aug 17, 2010
    18
    I managed 2 3CX v9 systems (one at each branch office). The video calling works fine for calls inside each system, but will not work for calls between the systems. Is there some option I need to enable for this to work across systems?
    Steve
