Video Codecs (not)supported in 3CX Windows phone system V15
Discussion in 'Ideas' started by freund, Dec 5, 2016.
Video Codecs (not)supported in 3CX Windows phone system V15 4.9 5 24votes
4.9/5, 24 votes
  1. freund
    Dec 1, 2015
    Dear 3CX R&D team,
    In order to connect video link from different IP intercom door stations to 3CX client on Windows PC we would like ask 3CX R&D team to implement some or all following Video Codecs.
    Video Codec H263 --> QCIF, CIF, VGA, 4CIF, 720P
    Video Codec H264 --> QCIF, CIF, VGA, 4CIF, 720P
    This implementation make possible to integrate IP telephony and IP intercom on front desk and offices in organizations.
    At present time it seems that only supported Video Codec are H.263-1998 and VP8 video codecs what makes 3CX client for Windows PC very limitted.
    For your reference Linphone is supporting all mentioned video codecs.
    Kind Regards
    Anel Bektas
  2. Saulius Balciunas
    Jan 13, 2017
    19
    5
    We have the same problem not only with doorphones.
    Our customer bought Yealink VP-T49G but can use only old H263 codec.
    While Yealink supports H.263, H.264, H.264 HP codecs
  3. Zuch
    Dec 21, 2016
    7
    6
    Agreed - H264 at least - its very common with any ip camera in 2017
    Matt Guttilla likes this.
  4. datasys3
    Nov 7, 2014
    Agreed - H264 at least - its very common ... not only for camera
  5. marcolagoa
    Oct 27, 2015
    7
    This feature is required from customers! they hate open the browser to see doorphones!
  6. jed
    jed New Member
    Feb 1, 2010
    153
    48
    Old case, but will there be any news regarding Video Codecs?
  7. Phone systems NZ
    Feb 15, 2017
    52
    15
    Please add H264 support.
