Video Conference
Discussion in 'Windows' started by NT4, Mar 26, 2018.
  1. NT4
    NT4
    Mar 18, 2018
    12
    Do you have any recommended video conferencing products? I tryed the Logitech conference cam connect but when connected to the laptop 3cx only picks up the laptop camera and doesn't give you a choice to choose the second camera. Is there an option to switch between cameras that I've over looked?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,422
    83
    Are you talking about WebMeeting or the ability to make video calls via the 3CX Client/s?
    For WebMeeting:
    -Go to Browser URL Bar's right side.
    -Click on the Video Icon.
    -Click "Manage"
    -Click on "Camera Settings"
    -Select your camera from the dropdown
    -Close this tab.
    -Refresh the WebMeeting tab or disable both Video and Audio and then re-enable them to switch to the new camera
    For the 3CX Clients
    -Go to Settings > Video Options > Select your camera
    -As a precautionary measure, restart your 3CX Client though it might not be needed.
  3. NT4
    NT4
    Mar 18, 2018
    12
    Thanks I've never noticed that little camera icon before. It will likely be a combination of both WebMeeting and 3CX Client/s that it gets used for. I'd like to put some dedicated video conferencing equipment in the conference room, that can be used in a stand alone capacity but I'm not sure which would work best with 3cx.
