Video Conferencing Bandwidth
Discussion in '3CX Phone System - General' started by techdummy, Feb 2, 2018.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    212
    9
    Does anyone know how much bandwidth is required to make One-on-One video call?
    Also any idea about what codec is being used?
    Thank you.
  2. techdummy
    Sep 22, 2017
    212
    9
    3CX video conferencing bandwidth!
  3. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @techdummy,
    The Video codecs that the PBX uses are VP8, H263-1998, H263 (you can check this in the windows client under your account's Advanced settings ).
    Now for calculating video conferencing bandwidth, you can make a conference test call and monitor the bandwidth throughput from the Performance tab of your task Manager
    Giving you just a number wouldn't be the right approach as the scenarios and needs vary.
    I would recommend making a conference test call similar to the average calls you are going to have(number of participants etc) and test.
    For linux you can do this with nmon or nload
    Commands:
    apt-get install nmon-for installing the pachkage
    nmon and then n for network monitoring
    Personally for network monitoring i prefer nload as it's simpler(nmon has many other monitoring tools though, check it out)
    Commands:
    apt-get install nload
    nload
    (by pressing enter it will switch to the loopback monitoring mode)
