video conferencing
Discussion in '3CX Phone System - General' started by smokeman, May 5, 2011.
  1. smokeman
    Dec 10, 2010
    50
    So, looks like we are go for purchasing 3cx. During the presentation to the bosses, the question was asked, can we do multiscreen video conferencing? Is there software out there that for the conference room laptop(showing on a projector), that can show all the webcams for the conference participants(if they are on webcam that is...with 3cxphone)
  2. willow
    willow Member
    Mar 1, 2011
    471
    doubt it. Probably be better off going with a real conferencing solution. I think the 3cx is more of a one to one video call.
  3. smokeman
    Dec 10, 2010
    50
    I found a solution that will work better for us anyway...
    bigbluebutton.org
  4. willow
    willow Member
    Mar 1, 2011
    471
    very nice product.
  5. mda
    mda
    Sep 13, 2010
    8
    Would it be possible to have a one on one videoconference in HD?
    We now use skype, but rather have it intergrated with 3cx.
  6. willow
    willow Member
    Mar 1, 2011
    471
    the 3cx phone does one to one video. there are also alot of phones out there that have cameras in them that also have tv outputs. you can even try Vu Presents as an option.
  7. rickywillson
    Jun 1, 2011
    I want to buy 3cx phone which having video conference and internet facilities. It should be on reasonable and affordable rates.If anyone knows then please update some information about this.
  8. mda
    mda
    Sep 13, 2010
    8
    I know video is supported, but in 3 cx phone i can only select as max resolution 704x576 pixels. So no HD 720p or 1080.
    HD is what I'm looking for. Is this possible?
  9. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    HD Video is not supported on any SIP softphone or hardphone. If you want HD video conferencing you need a different solution. Check out VU Telepresence http://www.voipstore.com/featured-solutions/vu/
  10. mda
    mda
    Sep 13, 2010
    8
    I think it is with e.g. livesize and maybe others.
