Video phone with wireless headset
Discussion in '3CX Phone System - General' started by jholcombe, Oct 22, 2015.
  1. jholcombe
    Jul 9, 2014
    79
    Can anybody recommend a good video phone that supports a wireless headset? The VP530 looks great, but I've noticed that it appears to only accommodate a wired headset... I need a video phone wireless headset where the user can answer calls, etc., with the headset.
    Thanks,
    --John
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    First, decide upon the phone. Second, decide on the technology of wireless that you want (DECT or Bluetooth). A few of the Video phones have built-in Bluetooth. However, several of the headset companies such as Plantronics, Jabra and vXI make wireless headsets and will have a cable or lifter assembly that can turn the phone into a wireless headset capable device. Jabra specifically has headsets for the VP530 which you can go to their site and use their compatibility guide to locate a suitable model.
    You may want to also call them and inquire as to what the compatibility means. Some may not be able to use the connect/disconnect function without you having to manually push a button on the phone itself.
