View Call Log without Loggin IN
Discussion in '3CX Phone System - General' started by glynco, Jul 15, 2007.
  1. glynco
    Jul 14, 2007
    20
    Can I view the outgoing CALL LOG report without loggin in?
  2. Anonymous
    Anonymous Guest
    Perhaps you should tell us what you want to do with the call log? You seem to be rather focused on the call log.
    The short answer is that you have to login to view the call log, even if you use ODBC you need to log in.
    If you are after deleting some entries which should not be there, eg phone calls made to numbers you do not want others to know, you are better off following the procedure outlined in your other post about deleting your call log.
    Two ways to get to the call log:
    1. using the management front end of 3cx
    2. using odbc to get to the db.
    Two types of users are able to login:
    1. admin, this is the one you setup when you intalled 3cx.
    2. using the phonesystem user.
  3. glynco
    Jul 14, 2007
    20
    What phonesystem user?
    Like user 101 password 101?
  4. Anonymous
    Anonymous Guest
    phonesystem__3cx__ is the user I am talking about, this user (besides admin) has admin rights to the db.
