viewing caller details
Discussion in 'Windows' started by hassanbright, Mar 23, 2010.
  1. hassanbright
    Mar 21, 2010
    Hi everyone,
    I just purchased the 4-line version of 3CX and I'm so glad with it features as well as flexibility with Voip providers & PSTN gateway. However the one of the downsides for this software, it doesn't show you the caller detials upon calling.
    for example in samson pbx you can insert a client phone number, address, notes,etc. and upon calling you can view these details.
    is there any solution for this issue? Will it be available in version 9?
    Regards
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Hassan,
    You could use the outlook integration with the assistant, this will bring you up all the data stored in the outlook database regarding the client that is calling.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Are you asking for more information on the subject, did not quite understand what you're after. If you after some information here would be a good place to start http ://www.3cx.com/blog/docs/assistant-integration/ - this link is no longer available
    #3 mfm, Apr 13, 2010
