Viewing/Reporting Bug List
Discussion in '3CX Phone System - General' started by darrellchapman, Feb 5, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    Sorry to cross post but I feel this forum is more appropriate for this question...
    Does anyone know where I can see a list of reported bugs and what is currently being implemented? If we had a way to reference this there would probably be fewer forum posts for help since I see the same questions being asked over and over.
    Also, what's the proper procedure for reporting bugs to 3CX?
    Your help is greatly appreciated.
    Darrell Chapman
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your post.
    We are currently working on this and forum posts shall be made once we are ready to roll this.
    You may create a post on the forums for any bug encountered. This should ideally include the support info together with hardware / software information and precise steps to repro the issue.
    The 3CX forums are actively monitored by support and testing staff who will then be able to take the appropriate action.
