Virual server
Discussion in '3CX Phone System - General' started by no1daag, May 8, 2007.
  1. no1daag
    Feb 8, 2007
    29
    Can someone recommend a good ( free ) Virual server?
    Found Virtual Iron how are free for singelserver but have someone test this with 3cx?
  2. etm_ltd
    Nov 18, 2006
    69
    Hi No1Daag;
    Have you tried to download for free the Mircrosoft virtual one?
    http://www.microsoft.com/technet/virtualserver/software/default.mspx
    It seems to be free.
    On my own, I have tried virtualization.
  3. Anonymous
    Anonymous Guest
    http://www.vmware.com/
    Like mentioned by etm_ltd is pretty good, especially the server version.
    I am a MS shop so I use(d) the Virtual server from MS. I stopped using it as i have no need for it anymore, but 3cx works just fine on it from memory.
  4. tcgmuc
    Mar 14, 2007
    59
    Hi No1daag,
    both will work; Microsoft Virtual and VM-Ware. Both are free to be downloaded via Internet.
    Greethings,
    Michael.
  5. no1daag
    Feb 8, 2007
    29
    Maybe should try that but it
  6. Anonymous
    Anonymous Guest
    If that is the case go VMware, i believe in the resource section there is a full iso you can download and run.
    http://www.vmware.com/vmtn/appliances/directory/694
    I think this is where you are looking for.
    Download
    Install
    Done.
    That is what i love about VMWARE, but I am getting to "old" to play with the toys LOL.
