Vista
Discussion in '3CX Phone System - General' started by spamoni, Feb 19, 2007.
  1. spamoni
    Feb 15, 2007
    20
    I was wondering if anyone could tell me if this PBX is compatible with Vista. I installed it on a Vista Machine and everything went fine. However, my VOIP Line does not connect. Upon further investigation, I found that only 2 of the services were started. The other ones would not start and I get an indication which states the application did not respond in a timely fashion?
    Can anyone shed some light on this.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Vista support
    Vista is not supported at this time but it is something we will look into to.
