Vitelity INBOUND and SOURCE ID parameters?
Discussion in '3CX Phone System - General' started by j_friedrich, Dec 5, 2009.
  1. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    I thought I would split this topic from the intial Vitelity topic I posted.....
    Under the 'Source ID' tab, We have the source identification by DID checked off. We have entered our DID numbers for our routing. We are not sure about the 'SIP Field containing DID numbers' field. We are having some issues where the calls are not coming in. Currently, the setting we have is 'Request Line URI:User Part'. Also, not sure about what parameters should be in the 'Inbound Parameters' tab? Currently, they are just defaults.
    Any suggestions?
    Thanks again.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    With the latest version of 3CX I am not having to enter any additional parameters for Vitelity and mine is working fine now. I only have to setup some additional pieces for outbound caller ID.
  3. j_friedrich
    Apr 2, 2009
    30
    Hi Kerry,
    Just thought I would throw that post out there. I have tried some of the defaults and there are some still some issues with calls not getting through. I will keep trolling for any other solutions and will post if I find something different.
    Thx.
  4. KerryG
    Jun 19, 2009
    960
    The guys at Vitelity are very easy to work with, if you are having problems, give them a buzz or open a ticket and I am sure they will help you get going quickly.
