Vitelity setup and callerid setup
Discussion in '3CX Phone System - General' started by j_friedrich, Dec 4, 2009.
  1. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Just wanted to know if anyone has a working setup for Vitelity. Currently we are using the default 'generic' setup but wanted to know if there is a more refined / better setup everyone is using. Also, having some issues trying to get the 'extension' callerid to pass thru Vitelity.
    Any suggestions?
    Thanks for everyone's time.
    Jason
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I use Vitelity and its working great for me. They are not certified yet so there is no template, for now just use the generic setup and everything should work good. To fix the outbound caller id issue, follow this article:
    http://www.voipstore.com/how-to-set-3cx-caller-id/
  3. j_friedrich
    Apr 2, 2009
    30
    Hi Kerry,
    Thanks for the quick response on the callerid! Second question for inbound did routing parameters. Under the 'Source ID' tab, We have the source identification by DID checked off. We have entered our DID numbers for our routing. We are not sure about the 'SIP Field containing DID numbers' field. We are having some issues where the calls are not coming in. Currently, the setting we have is 'Request Line URI:User Part'. Also, not sure about what parameters should be in the 'Inbound Parameters' tab? Currently, they are just defaults.
    Any suggestions?
    Thanks again.
  4. KerryG
    Jun 19, 2009
    960
    I only have the defaults being used. I used to have to do some other settings magic until a recent 3CX build that seemed to fix that.
  5. j_friedrich
    Apr 2, 2009
    30
    Tried the callerid settings for vitelity as suggested. It worked initially, but, now vitelity returns the id '12345678912'?
    Nothing changed on my end. I also opened up a ticket with vitelity but they don't know 3cx. They basically told me to check my caller id settings in the outbound trunk....no kidding.
    Anyways, thanks for everyone's help.
    Jason
  6. j_friedrich
    Apr 2, 2009
    30
    Hi guys,
    Messing around with the outbound parameters, we are having better luck at passing callerid using the following settings:
    Remote Party ID - Calling Party : User Part = "OutboundCallerID" Outbound caller Id taken from Extension.....
    Remote Party ID - Calling Party : Display Name = "CallerDispName" Display name of a caller as it is in.....
    Give it a try and see if it works better for ya.
    Jason
